Two state shapes for Weintec HMI?
CalG
Feb 2013
VT
197
I would like to use very simple two state valve and pump shapes
on an 8070 HMI. (push the button, see the state change on the graphic).
Having downloaded all the optional libraries from the Weintec site, I still do not see two state shapes for simple valves (X) or pumps (V). There are many for buttons!
What is wanted are monochromatic (gray scale) shapes that fill (color would be fine) when open/energized.
Have I missed something? I am very new to these Graphical user interface options.
TIA
Cal
With Weintek software, you need to make your own.
Maple Systems sells Weintek under their label. Their software has multistate objects. Get a copy of their software, then copy the libraries you want into your Weintek software.
We have a new machine that uses an armor block to transfer input signals for conveyor position that continuously alarms out on no position change...
90
Good Morning , I installed an AC Tech ESV 1 HP Drive on a small bucket conveyor. Before it had a DC Motor on it . It now has a Baldor 1 HP...
210
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,067
I'm trying to add on to a safety circuit and trying to make sure this is fail-safe. My safety scanner needs some muting when things aren't running...
827
Hello all, I'm coding on a CP2E-N with CX-programmer and trying to get my head around some of the clunkier parts of it, since I'm more familiar...
2,837
