me three... everything gets grounded unless it's absolutely nececary to do otherwise. big majority get's negative side grounded but we have equipment where positive is tied to ground. i absolutely hate to see -24V unless this is correct or what meter will show. if i measure between -24 and +24, i expect to see 48V. if not, that psu (or panel) is garbage and needs fixing....[/QUOTE]
I am confused on this statement, why would you have a PS that measures +24 and -24 to equal 48vdc? Why would a panel have a 48vdc power supply?
ANY 24 volt dc power will have +12vdc and -12vdc output, IF you tie one of those to ground then you will have a 24vdc to zero (common) connection, whether plus or minus depends on the connections.
Whether you measure + 24 or -24vdc depends on how you connect a meter, they are polarity sensitive.
IN SOME CASES a center tapped connection is involved with 3 wires i.e. +12vdc, COMMON, and -12vdc, you get 12vdc between common and either of the 12vdc points, whether + or minus is AGAIN an issue of connection, not source.
ITS RELATIVE.
Technically there are no standards, legal issues, or safety issues that require a 24vdc PS to be grounded, in many cases grounding a 24vdc PS can create issues i.e. induced voltages from AC sources etc.
NOTE: The term neutral should never be applied to reference the negative or common connection point of a DC supply.
