Ultra Drive 3000
tlona
May 2007
New Jersey
33
I am new to ultraware and am trying to change parameters to and existing ultra drive 3000. I can successfully connect to the drive through the serial port on the back and establish communications. But how do I make changes to the program and reload it to the drive? Thank-you
Normally when you make changes in Ultraware, they are applied immediately to the drive and there is no need to upload or download (if the drive is connected at the time). It all depends on whether you are looking at an Online or Offline drive in the lefthand pane. If you make changes to an Offline drive and later connect to it, you can drag the Offline drive icon onto the Online drive icon and it will overwrite all the parameters.
If you can already communicate with the drive as you say, then you should see it listed under Online drives. Just make your changes directly.
great Thanx. I was not sure if it was a simple drop and drag. I was able to copy the online parameters to the offline file. Was not sure it worked the other way and did not want to screw it up.
Thanx again
Hi guys I am using three ultra 300 drive on device net and the issue i am facing is that when one of the drive faults it stops the operation of...
1,627
Fault E10 displayed, book says excessive regeneration of power. dont think thats the problem. any other ideas? motor drives a right angle gearbox...
3,824
Working on a new project where I'm trying to use a Ultra 3000i servo drive and a Red Lion G3 servo to be do the following: 1. Feed material...
3,356
Hello all need some help. I have a CNC machine that uses 5 Ultra 3000 servo drives. The X axis drive goes into a E21 fault sporatically...
4,102
Hi, I'm trying to connect two drives (axis). I managed to configure one of them and it works fine, but when I add second one to Sercos ring only...
1,542
