Ultra3000 Faults in Rotary config on an L43
NevisGroup
Jan 2014
Wisconsin
78
So I have had this machine dropped in my lap.
I have an L43 chatting with an Ultra3000 drive (via sercos).
When I configure the axis to be rotary, the drive faults with error E33 as soon as it crosses the roll over point.
The reported position is correct but the drive is faulted.
I if I configure the drive as linear and do a MRP when ever it rolls over all works fine but the MRP is a little late some times. ( i.e. if a have a repeat of 12.00 I may see a position of 12.200 before the MRP wraps it back to 0.200)
( This fault happens regardless of the following)
Ideally I want to change the roll over point on the fly via a GSV. That works fine and when I look at the axis config it reports the correct roll over.
The drive reports to be : 2098-DSD-HV150-SE
The motor (which I can not see) reports to be: MPL-B680F-M
Good afternoon all, We have a carton machine with 7 Ultra3000 sercos drives controlling various servo motors. From what I understand, It has...
444
Hello, I have an issue with one Ultra3000 servo drive. I command an 1326AB-B520E-S2L motor and after 30 min the drive goes to fault with the E22...
1,653
Ok so first allow me to bow my head and say I'm a retired mechanical engineer and while I still have a few brain cells left there is something I...
3,971
Anyone know what might cause this? All my other drives are working fine except this one. Sometimes I can start the drive, it'll run fur 5 seconds...
2,002
Hey all, For a school project I've been tasked with getting a ControlLogix, Ultra3000 and some servos that were donated up and running...
1,583
