Unity pro xl or step 7 professional as starting point?
abdq
May 2017
indonesia
I've an opportunity to learn a plc as a new employee. I don't have any technical experience about plc (even programming) after reading some references there seems to be a paradigm to use structured text that platform independent and more like future proof. Thank you.
Learn what you will work with. I work with more PLCs than I like to (Siemens,Omron,AB,Schneider,Mitsubishi) but have no choice but to learn at least enough to troubleshoot and do some minor modifications. I started out with Siemens and hated it at first and now that I got to know it somewhat well I now hate Omron :D because the environment is very different from TIA but a lot of the equipment I'm dealing with these days and for the next few months to a year will be predominantly Omron stuff so I have no choice. I program in ladder and SCL depending on what I'm doing. I even spent the time to replicate on Omron some of the reusable blocks I developed on TIA.
I drew the line at Wago and Sigmatek, there's just not enough of them out there that I don't want to know anything about them and rely on OEM support for troubleshooting.
Future proof isn't something I'm familiar with but the more you know the more valuable you will be.
Thank you for the information.
I guess I will choose SCL siemens with s7-1200
Greetings, I'm new at PLC programming, but good a logic - so I thought. I've inherited a PLC system, which is presently operating in the field...
2,491
Good morning, I've got a Schneider M340 PLC that I'm commissioning with Unity Pro XL V11. There is an SFC in the software but it seems to be...
3,082
Hi All I have recently started using Unity Pro and am currently coding a process sequence. I need to be able to pause the sequence for which I...
5,763
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
405
