Unmanned Offshore Platform ESD
svn
Jul 2004
74
To replace the pneumatic/hydraulic ESD/FSD panels on unmanned oil/gas well platforms with PLC based system which SIL level (as per IEC61508) is normally sufficient? These platforms have 8 t0 14 wellheads, test separator and other utility systems. The Oil/Gas is sent to manned Process Platform Complex for processing.
After searching on the net I found that some system integrators have used AB Controllogix redundant system, some have used GE Fanuc Series 90-30 based redundant system and some have used Triconex TMR systems.
As far as I know, Controllogix can be used upto SIL2 Level. GE Fanuc GMR system (which can be used upto SIL3) is based on Series 90-70 and not 90-30. Does this mean that SIL2 is sufficient for these system?
SVN
I'm not sure about the sil level but,
I'll Take a Triplex over a Triconex anyday.
Hello, Looking at quoting a system with a 100hp motor for offshore use. Motor is only used a few times a month. I’m thinking I might need to...
2,221
Guys, I'm having a problem with Autronica Autrosafe system. It is a rig fire & gas system, for accomadations. This system is freezing almost...
5,381
And especially oil rig of different types? I´m thinking of trying some new branch out, someone here that have worked with design of systems to...
3,014
Hello, I am trying to implement some data coming from an Compressor Controller, but cant quite figure out what i am supposed to put into the...
139
Hi all. I received two identical brand new Dell desktops from a customer to install the softwares for a project. The first one is for a...
531
