Unused pins
kvogel
Jan 2011
Colorado
106
I admit this is an OCD question but it I'm curious. Should the unused locations in a connector be filled with unwired pins or left unfilled. Particularly, I'm building a encoder cable which uses a d'sub 15 and only 8 wires in the cable. I've seen commercial connectors with a full set of pins where I know all pins aren't used and some built with open spots. It probably doesn't matter but is there a preference?
Ken
I suspect that the difference you're seeing is between a solder style D connector versus a crimp style connector. I personally prefer the solder style connectors, but I'd never bother to insert unconnected pins into a crimp style connector.
Two or more unused jumpered pins could also be used to verify that the plug is in place, for fault detection. Knowing that the plug is disconnected could distinguish between a plug failure and an encoder failure.
When I build a cable with crimp style connectors, I leave the unused positions empty to conserve components.
The other benefit is that you can often look at the end of the connector and guess what it's for (or not for) based on the pins that are present.
Hello everyone, how can I see in machine edition (in 1 overview) which variables are not in use? When I create a new variable it continues with...
569
Hi. I always do my best to terminate all cable wires, including unused wires. But I find that it gets difficult when for example I have...
21
8,289
Curious if anyone has a tool or method for removing the unused images from FactoryTalk View Studio Machine Edition. Our customer has provided a...
1,764
We are using a 1756-IF16H that has a few spare channels. The channels that are SPARE are indicating a channel fault. Is there a way that I can...
2,133
I am using Proficy Machine Edition 6.5 for a PLC. In a ladder logic program, I need to assign a register to a timer value. But, how do I find...
1,576
