Unused UDT item cleanup
jholm90
Mar 2012
Ontario
155
Was curious with best way to find and clean out unused UDT items? I've been online with other programs before with 20+ elements that are not used in the program and it makes browsing and monitoring things a tad bit over complicated.
The only way that I've found is to delete all UDT items, compile/verify the controller and note down the missing tags. Cross reference only seemed to work on a tag by tag basis.
I appreciate your insights..
It reports all of the instances of the UDT but not the member usage.
I would do it old school, export to a .L5X file and run some searches with an editor like notepad++.
Maybe it depends on the version. In 29, if I cross reference the base UDT tag from the Controller Tags list, I do get every reference to everything in it, but then I can sort on the 'Reference' column to put them in order.
True. The OP said cross reference the UDT, not the tag of the UDT instance and there is a difference. If the UDT definition is cross-referenced in the Asset tree, it will report all of the tags that are of that instance but not their member usage.
Hello everyone, how can I see in machine edition (in 1 overview) which variables are not in use? When I create a new variable it continues with...
569
Hi. I always do my best to terminate all cable wires, including unused wires. But I find that it gets difficult when for example I have...
21
8,264
Curious if anyone has a tool or method for removing the unused images from FactoryTalk View Studio Machine Edition. Our customer has provided a...
1,760
We are using a 1756-IF16H that has a few spare channels. The channels that are SPARE are indicating a channel fault. Is there a way that I can...
2,130
I am using Proficy Machine Edition 6.5 for a PLC. In a ladder logic program, I need to assign a register to a timer value. But, how do I find...
1,572
