Updating software on SIEMENS SIMOREG 6RA70
M/B
Apr 2006
Lokeren
Hi there,
Following procedure for updating software on 6RA7013, stuck at step 5 (for those who have the manual) where you open a dos window and give the command C:\6RA70\HEXLOAD 7001Axxx.H86 7001Bxxx.H86 COMx.
Connection Simoreg-PC is succesfull, but I get the following error: Can't find file 7001Axxx.H86.:unsure:
Anyone done this before??
Kind regards
I've been doing that, I put the xxx to generalize when explaining the problem.
The specific version I'm dealing with is 2.26, and the port I'm using is 1 thus making the command C:\6RA70\HEXLOAD 7001A226.H86 7001B226.H86 COM1.
The problem is that it fails to locate the files in question giving the error: "can't locate file 7001A226.H86".
I can locate the same files in the same DOS window simply with a DIR command.
With the DOS windown open, rather than execute the the command 'C:\6RA70\HEXLOAD 7001A226.H86 7001B226.H86 COM1', from C:\ have you tried changing directory to C:\6RA70\ and simply using 'HEXLOAD 7001A226.H86 7001B226.H86 COM1'
That's the one.
I asked a friend at work who's more experienced in DOS and he said the same thing.
Did the upgrade, works like a charm.
Thank you so much krk, "you the man".
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
88
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
135
Is there anything I Should take into account while updating the firmware on a safety processor? I have a 1756-L61S running version 17 and need...
103
Hi, I'm trying to figure out how to properly update the "icons" on my Panelview 900 (AB 2711-T9C9). I think maybe I'm having a fundamental...
1,001
Hello everyone, I am dealing with something annoying and excruciatingly basic that I am just ready to cry. I have updated some alarm messages in...
940
