use of client only
kraj
Feb 2010
p
82
i hv opc server and wonderware scada as software
and our applicon client is not working
so
can i purcahse only client is it possible or
anything else
please sugest a proper solution
thanks in advance
is it a tough que.
is it really a tough que. or what
there is no response
hey iam new in opc server and lient so need a help
so
anything else
thanks in advance
Hello,
It is kind of hard to answer. You say 'our applicon client is not working' but not what part is not working. Is 'applicon client' an OPC client?
You say 'can i purcahse only client' but not the type of client.
If you want to know if you can purchase an OPC client the answer is yes.
PeakHMI has an OPC client.
Good luck,
Mark
http://www.peakhmi.com/
thanks
thanks
i have applicon app-ps7-pci
puc1500 s7
that is our client thats is opc client
and this time it not work i means not getting data
so
and i have s7 opc server made of softing
is it possible to replace only client
as per ur suggestion is ur client is working :confused:
Hello,
Good luck,
Mark
hmmmm
i think im getting confused???
Hello,
Good luck,
Mark
mark can u please guide me on this topic
Hello,
The more data you supply, normally, leads to more communications.
From your messages it appears:
You are using an Applicom Profibus card
You are using a Softing OPC server
You are using an S7 PLC of unknown model
You are using Wonderware
You want Wonderware to communication with the Softing OPC server which communciates with the Applicom Profibus card which communicates with the S7.
You say your client is not working. I assume you mean Wonderware.
You ask if you can purchase a client only.
My answer was PeakHMI has an OPC client. (included in the base price)
Since you say the client is not working that assumes all the other parts are working. PeakHMI can communicate with the Softing OPC server.
Or you could use a Serial to MPI adapter and PeakHMI would communicate with the S7 without Softing or the Applicom. Or if S7 has Ethernet you would not need the Serial to MPI adapter.
Good luck,
Mark
thanks a lot
Thanks a lot mark
Hello,
Good luck,
Mark
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
26
I used vmware converter to clone and backup a physical pc FT View client and now after removing vcenter converter and rebooting I am getting a...
81
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
111
Hi everyone, I've got some trouble lately with a client and his communication with the server. I'm a beginner, and the project was not orginally...
93
Hello, I'm working on a laptop that needs FactoryTalk Activation Manager installed on it as a host along with a Hyper-V VM client on the same...
109
