I don't understand exactly what you are saying. What you should be seeing when you open the picture that I sent is the following:
1. The first column shows the avaliable Channels 0-7
2. The second column allows the programmer to enable(or not) each individual channel of which I have chosen to enable, with a check in each box, channels 0-4
3. The third column is the input range of which I have chosen4ma to 20ma for each channel(even the channels which I did not enable 5-7)
4. The fourth column is for filtration and I chose 60Hz for all 8 channels even though I am only using channels 0-4
5. And for the fifth and final column available titled "Data Format" I chose Engineering Units for all 8 channels again even though I am using only channels 0-4 thinking that might be the easier way to go.
So, shortly, I will again post the module configuration entitled "1769-IF8 Configuration Tab" for further review. Please let me know if you are still seeing only voltage formatting.
Thanks for your patience,
Lloyd
