VantagePoint - Display update rate
mike1234
Oct 2017
midland
I am having difficulty in finding out how to edit the tag update rate for a display in Vantage Point. Currently the display seems to update approx every 10 seconds. Is it possible to get a faster response on the displays?
Tags are currently straight from PLC (via FactoryTalk - localhost - LiveData)
The answer to your question is I don't know, but..........
I was looking at using vantage point a few months back, but I ended up using the built in VNC viewer side of things.
A lot lot better than vantage point.
Cheers
Mark
Assuming you build a dashboard for this -
You set the 'update' rate of the xml data under Data->Connections under the Usage, Refresh options, You'll have to then republish the dashboard.
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is...
138
Hello, I am trying to use VP Trend on a Client PC. I can bring up the webpage, but I get these 2 different popups when trying to download the...
658
When trying to install VantagePoint on the server I get the error SQL Server Connection Test Failed: A connection cannot be made to the database...
1,580
We have a client with 24/7 operations with batch reports that include queries of process values from an FT Historian. They do the reports in SQL...
1,525
Hello, I have a FactoryTalk Historian where I've configured some tags to record a couple of signals. This bit works as I check the historical...
1,741
