Versamax CPU002, R2000 Fanuc Robot and Quick Panel
Davev2005
Jul 2005
San Luis Potosi
23
It's Possible Create A Lan With A Versamax Cpu005 Or Cpu002 With The Serial-ethernet Converter , Fanuc Robot With Egd And Quick Panel (ic754vki12ctd).
I Need A Hub Or Switch?
What's The Guidelines To Do It?
You will want a switch to creat the Lan, however you will also need to get rid of the Serial-Ethernet adaptor and use the VersaMax IC200CPUE05 to communicate EGD to the Robot. The QuickPanel will want to talk SRTP to the PLC on Ethernet.
Yes, it is possible to have an Ethernet Lan made up of devices that do not talk to eachother. The lan can have more than one protocol for different devices. The Robot can talk to the PLC with EGD and at the same time the HMI can talk to the PLC with the SRTP protocol, both protocols are on the same Ethernet lan. Your PC can then talk to each device with yet another protocol. You just need to be aware that the devices that must communicate to eachother have the same protocol available to them.
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
222
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
138
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
395
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
434
I have a new computer and it doesn't have an ethernet port. I am trying to connect to the Versamax Micro Plus with a type c to ethernet adapter...
1,254
