Versamax Nano programming cable
rbz
Sep 2008
mexico
22
Hello
Does any one knows the programming cable pinout (RJ11 to DB9 Female) for a versamax nano PLC P/N IC200UDR005?
Thanks in advance
The cable I did last week worked perfectly. Now I have another PLC but this time is a nano. It has a RJ11 (6 cables) connector not a RJ45.
According to the documentation I have, the IC200UDR005 is a 28-point Micro with one RJ45 RS232 port and one 15-pin Dsub RS485 port. The same documentation says that all six models of the VersaMax Nano have one RJ45 RS232 port. Part numbers for the Nano units are of the format IC200Nxyzzz.
The only GE Fanuc Micro PLC I could find with an RJ11 port was an old unit that predates the Series90 Micro. That line's part numbers are prefixed IC620.
Let me check the information I have, sounds like I have wrong information. So the same cable a made last week for IC200UDD120 will work also for IC200UDR005?
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
237
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
145
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
406
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
446
I have a new computer and it doesn't have an ethernet port. I am trying to connect to the Versamax Micro Plus with a type c to ethernet adapter...
1,270
