VersaMax
jamesnie
Oct 2017
Blackburn
Merry Wednesday!
Can someone enlighten me on the difference between the IC200UDRE005-CH and the IC200UDRE005-BA
what do the "CH" and the "BA" refer to, and would it have any efffect on communications?
We have a customer who has bought the BA version from us and is saying it wont communicate with his laptop, he sent it back, and it was tested again, both ports working fine. Again, he says the same, this time with a video, and sure enough, its not communicating with his laptop.
I noticed in the video the model numbers were different (the BA and CH variants) and that he was using a SNP to RS232 converter.
We do not deal with Fanuc PLCs and Proficy very often, so knowledge of them is very limited. if its not the model numbers, what in the program could be preventing it from communicating?
Odds are its his USB/SNP converter (they are all not created equal).... the last two are firmware codes, so if the ports are good he should be able to connect regardless of the firmware as the ports should be the same
Mark is correct that the last characters of the part number denote the revision level. The OP should suggest to the customer to check the COM port number assigned to the USB/serial converter and make sure it matches the port the programming software is using.
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
222
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
138
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
396
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
435
I have a new computer and it doesn't have an ethernet port. I am trying to connect to the Versamax Micro Plus with a type c to ethernet adapter...
1,256
