View ME runtime anomalies
byarsm
Apr 2018
Midwest
Hello,
I am running into an issue on several FTView ME HMIs where buttons seem to stop working after several months of running. The problem is "fixed" when the runtime file is restarted. Has anyone seen a similar problem in the past and found a fix?
The system runs several FTView ME (v10) HMIs on industrial PCs with Windows 10 OS. The facility buys View ME runtime licenses instead of panelviews because they like the having a larger screen.
Edit:
After a little further investigation it appears only GoTo display buttons stop functioning. The buttons seem fully functional after a reboot and seem to stop working after long periods without a reboot.
Is it set to replace or popup, I seem to remember some problem if set wrong, however, I cannot be sure exactly what it was.
I'm trying to assist a customer with this one. We were only given a runtime file, which can't be reversed, so we're forced to the backdoor method...
2,456
I have been trying to add a button to an HMI Panelview version 5.1 for a couple days. Each time I download I get no data in my buttons, only...
213
Hi there! I got a HMI terminal Panelview Plus 7 (PN-332439 / CAT 2711P-T12W21D8S) which work on a APP 8.00 i'm trying to modify with my FT View...
702
Hi Guys, I developed HMI with Resolution of 1920 x 1080 in FactoryTalk View studio SE; and also use same resolution for Client Runtime PC yet...
562
I am able to hook up my panelview to plc and set them on the same subnet and through the runtime shortcut the two devices. However, in the field I...
1,550
