VIPA CPU 114-6BJ02 program upload problem
Gmort27
Jun 2015
Singapore
Hi guys, I am trying to upload a program to my VIPA CPU 114-6BJ02 using a MMC but the MC LED does not blink to indicate the program uploading. What could be the reason? Any way to solve this issue? Thanks!
Ok thanks Nonuke! Already did the reset. My vendor sent me a .wld file, was told that I need to transfer it to MMC using Siemens Simatic manager, then upload to the CPU. Is that the right way?
Open step7
Create a new mmc file with the name:s7prog.wld
The file must have this name.
Copy all the blocks, DB's and the system data to the mmc.
Close the window of the new mmc file.
Copy this file to the mmc card.
MMC: normal mmc card formated in FAT ou FAT16.
No SD or MMC-HD. Just use a standard MMC of 32K, 128k, 512k ou 1M max.
These type of cards are not easy to find on sale anymore.:mad:
If you already have the .wld, just make sure it is named S7PROG.WLD, then put it on a MMC formatted as FAT16. Put the MMC in the CPU, then perform the Overall Reset procedure.
Check out page 3-30 of the 100V Manual for more details: 100V CPU Manual
Yes I have the S7PROG.WLD file, but I could not find a VIPA MMC, so using a Siemens MMC instead, possible to work? Sorry it's my first time doing this. Btw, how to make sure that I format as FAT16 instead of FAT32?
I believe the Siemens cards are formatted in a proprietary way, such that you may not be able to format them as FAT16 or when you do, it would no longer be able to be used with a Siemens PLC.
Anyway, if you would like to try, to format a MMC you would open up the Windows command prompt and type
FORMAT G: /FS:FAT
Where G is the current drive letter of the MMC card.
Caution!
If you reformat a Siemens MMC to either FAT16 or 32, It cannot be used as a Siemens mmc. in a Siemens CPU. It will be a very expensive and low capacity card!
Caution!
That is correct, I mentioned that in my original post after he mentioned he had a Siemens MMC.
hii friends, we do not have a source program of it. Siemens manager 5.5 can not upload its program fully because one db is big enough to stop...
2,038
Hi All, I have a VIPA PLC (CPU 114-6BJ02) that has a SF fault and in STOP. I have never seen one of these PLC's before I got a call to it...
4,939
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
177
Hello Friends I need to monitor a PLC Vipa. Which software and cable do i need? The upload will have the comments? Thanks in advance.
1,546
Hello all. I have trouble getting online with TIA portal V15.1 with a VIPA CPU(VIPA 315-4PN12). If I try to connect I get an error message that I...
3,377
