what's the meaning of Micrologix PID .CVH?
if I set PID .cvh =0, override out to 0, and if I set pid .cvh =0, override pid out to 100?
Some context would be nice. Exactly which MicroLogix are you talking about. PID.CVH is the Control Variable High Limit in Percent. The valid values are 0-100. I am not sure what you mean by override PID Out. Can you fill in some details?
Stu....
In Controllogix, PID has Override bit to set pid output to special value regardless of the pid mode, I don't know if in Micrologix has some function in pid. As you said PID.CVH is the Control Variable High Limit in Percent, this is different with override status. Thanks a lot.
Stu....
Hello: One customer has an application using 1715-IF16 on EtherNet/IP for the Rockwell side and HART master for the sensor. Everything is OK and...
1,810
This is in an existing application, so stuff I've found and I'm trying to debug. I've got no Tech support contract, so can't view Tech Notes :/...
1,577
Hey guys So when im online and i look at my tag list Some values show up with a white background some show up as grey What is the difference...
1,190
Hi, Can some explain me what's the measining of this option inside hardware configuration. When should I want/need this option to be...
2,939
Hi guys does any one know what does the specs on electrical wires mean....1sq mm (1/1.13)....what does that specs in brakets mean
1,806
