Which version of Step 7 do I need?
strantor
Sep 2010
katy tx
401
I'm a Field Service Technician, with a laptop running XP SP3. I have run into a couple of jobs where I needed to go online with a Siemens PLC but did not have the software. I have gotten the green light from my boss to get the software, but he's left it to me to find out the proper software package to buy. When I search my local Siemens distributor for "Step 7" I get 61 results, ranging from <$100 to >$4000, and I have no idea which one I need. I have used Step 7 and WinCC before with a previous employer, but I did not source that software and do not remember what package it was.
What I need is a version of S7 that will work with my laptop and let me go online/edit just about any Siemens PLC that I might come across in the field (very vague, I know). I don't know what add-ons or big packages that might require. Can somebody throw me a bone? what should I be looking for?
Thank you.
I'm afraid your not going to get an all in one package.
If the PLC is a S7-200 PLC then you will need MicroWin (should be able to get this from your rep for free).
If it is a S7-300/400 then it is likely to be classic Step-7 Simatic Manager. I believe the latest is V5.5
A new PLC of the S7-1200 or S7-1500 range would need TIA Portal.
S7-300 and S7-400 PLC's can use TIA Portal, but the program would need to be converted and you would need a copy of classic on your machine to do the convert.
Hello guys, I have a step 7 project that is together with WinCC flexible 2008 and I need to convert it to TIA 15 SP1. I would like to use the...
24
8,946
Good day to all.. I was previously using Simatic Manager Step 7 Version 5.4 SP 3.1 in my laptop with operating system MS XP Professional. I have...
2,316
I've been tasked with building some simulators for some legacy S7-3152DP systems. They are all programmed in STL, so I've determined that the...
10,284
Greetings everyone, I'm currently working on a project where I've to convert an old Step 5 program with comments made in German into Tia...
3,570
I have to make a test setup using Siemens IM 151-8 PN/DP CPU and 4SI IO Link module, to connect sensors over IO link. I will be using PROFINET as...
1,331
