Win10 for PLC Laptop ?
Those who use VmWare,
Do you use VMWare Workstation 12 Pro?
How many virtual machines can you set up?
Do you setup a Virtual machine for RSLogix 500, and a different Virtual machine for RSLogix 5000?
How does XP and Win7 operating system licencing work?
Is the VMware program one time purchase or a subscription?
Sorry if this is a hijack on your thread.
You can set up as many VM's as you need. I typically set one up, per project; and that way have a good starting point, if I ever need to return to the site.
Buy an external drive, and archive the heck out of them.
But, start with a very clean, fully updated BASE VM, and keep it pristine.
And, its hard sometimes, but tell yourself that you will never install software on your base machine....always use VMs for everything. Life will be good.
And, when your base needs replacement, you're ready for it, since all the good stuff is on VMs.
I second BlueAltezza on MSI gaming laptops. You take a hit on battery life, but everything else is great, especially the number of M.2 SSD slots (2 SATA and 1 PCIe for my old GE62).
I have a Win10 64 bit host for my OPC DA server, which is Indusoft (Studio,Scada.OPC.3). Locally OPC works, Matrikon OPC Explorer. On my Win7...
1,175
Greetings! I have had the extreme pleasure of being introduced to Rockwell's Win10-based PanelView Plus 7 and after having an extraordinarily...
2,380
Guys I know this may not be a PLC question but I do have a issue that I was needing some advise. I was needing to know the best way to create a...
1,941
So I just recently got a new win10 laptop for work, and I just found out that win10 is NOT supported for connecting to the PVC C400, C600 using...
1,377
I have a client who is looking to upgrade from Win7 to Win10, they're currently running NI Lookout 6.7.1 on the Win7 machine, it's a 64 bit OS...
1,280
