Win10 Multiple Monitor Coords
Sapper307
Nov 2017
Maryland
107
I know its not really a PLC question, but hopefully someone may be able to point me in the right direction. I have to configure a seamless KM, which by default comes out of the box with some reconfigured patterns none of which are multiple monitor machines. I can build a custom configuration that allows for multiple monitor machines to be on a single KM port thus allowing both windows extended desktop and the KM to control the flow of the mouse from one KM port to another once if extended past the second of two side by side extended monitors. The problem i'm having is that i need to manually configure each of the multi-monitor displays monitor vertical and horizontal coordinates. Back in the day you could just go to your display setting and when you moved your monitors around in the positioning window you would see a little coordinates value (looked something like (-1366, 312)) or if it was your primary monitor (0,0). Now in the wonderful world of Win10, it doesn't show us this because we are dumb and we don't need to know these things.
Does anyone know how to determine multiple monitor coordinates in Win10?
I have a Win10 64 bit host for my OPC DA server, which is Indusoft (Studio,Scada.OPC.3). Locally OPC works, Matrikon OPC Explorer. On my Win7...
1,180
Greetings! I have had the extreme pleasure of being introduced to Rockwell's Win10-based PanelView Plus 7 and after having an extraordinarily...
2,382
Guys I know this may not be a PLC question but I do have a issue that I was needing some advise. I was needing to know the best way to create a...
1,943
So I just recently got a new win10 laptop for work, and I just found out that win10 is NOT supported for connecting to the PVC C400, C600 using...
1,378
I have a client who is looking to upgrade from Win7 to Win10, they're currently running NI Lookout 6.7.1 on the Win7 machine, it's a 64 bit OS...
1,282
