WinCC Advanced Historical Data.
DLMUK
Jun 2013
Southampton
311
I am currently logging the value of some data tags using Historical data lists however when I view them in Excel I get one column with the header
VarName;"TimeString";"VarValue";"Validity";"Time_ms"
Is there a way that I can separate all of these out into individual columns or specify what data I want. I do not really need to see the validity or time in ms.
Thanks,
You need to tell excel that the ; is the separator of the cells. Now it sees it as one cell but if you tell excel to see ; as a separator it will separate the columns at each ;
I am using Excel 2007, so your stuff may be different.
Position cursor on the cell with the semicolon separated values.
I went to 'Data' tab, select 'Text to Columns', then:
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
78
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
282
Dear all, in wincc advanced RT (same as in wincc flexible), when connection to PLC is loss, output field (real) goes to ####. I suppose that tag...
161
I created a project with Tia portal wincc runtime advanced PC station and also activated its smartserver for some smartclients to connect to it...
333
We are rewriting software for a Simatic PLC/HMI originally made with TIA Portal V16. We will make use of a library that was developed for V17...
1,598
