WinCC Flexible 'disable operation' possible ?
Ok
Ok
Yes. setbitwhilekeypressed, Kalle reports that sometimes it does reset when you release the key so always reset in plc then map the key that way it wont matter and if the hmi comms fails the key press is reset in the PLC.
Thanks for the example getting it now
I dont know why I wrote SetBitWhileKeypressed.
I meant to write SetBit.
Exactly like Kalle said, I evaluate the bit in the PLC, and unconditionally reset it.
Dear Expert. I have problem to rotating the objects. (object from Graphics) Tool bar, Format menu, Rotate is disable. Is there any option to...
2,120
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
271
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
113
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
759
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,586
