WinCC to Excell or OPC to Exell ?
userxyz
May 2002
any
2,768
How can a send the data from this window (see image) to an Excell sheet automatically ?
If this isn't possible, then I'll need OPC I guess ??
As far as I remember, Combo uses WinCC Flexible, not WinCC.
(a small rant: I really dislike it when people cut off parts of terms and names. It is a source of confusion and mistakes.)
Also, from looking on the screenshot, I would say that you are after some kind of datalogging. Or maybe this is some kind of recipy or batch jobs. Please explain exactly what you want to do. We cannot know from guessing from a screenshot.
In case you really need to exchange data directly with excel, then there are 2 options with WinCC Flexible:
1. Add the option WinCC Flexible OPC Server. Then all the configured tags becomes available for OPC Clients.
2. Simply use the Simatic Net OPC server alongside WinCC Flexible. The HMI RT must then be part of a PC Station together with the OPC Server.
If you use Ethernet, then this is particularly clever, as each RT license is bundled with a Softnet Ethernet Lean license.
How to get the data from OPC to Excel:
Find Siemens support entry ID 24299099.
I have always used DDE with AB processors. In the formula bar you should see something like: =RSLINX|Dryer!'N9:7' The pipe | separates the driver (RSLINX) from the Topic (Dryer) the exclamation point ! separates the Topic from the word/bit address which is in 'single quotes.'
I'm sure that there is a difference with Seimens, but the Excel side should be close to the same. I have only recently started using OPC, and have not had the chance to import to a spreadsheet with it yet.
Note that the Alarm-page he uses is the one used in WinCC. I believe for this application he uses WinCC. Not WinCC-Flex.
But I agree on the small rant :D
Hi, I'm still doubting about wich way to choose... hmzz There will be a machine, with ethernet connection to an Office PC. They want to be...
57
18,199
Is it possible to import alarms into WinCC felx 2007 from excel. I especially mean the alarm texts. We need a couple thousand alarms and the texts...
8,551
Hi, I know that you can export a translation of alarm messages... by right clicking on DISCRETE ALARMS and choosing for export. But, I want...
3,869
Hi, We do alarm-logging in WinCC. Is there a simple way to transport the alarm-logging data automatically to an excell-sheet ? Or another way...
1,914
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
80
