hmm
Okay,
you can import recipes, but, these are CSV files, these need to have the correct format...
I mean, I will not get a step further by this, because, I can store recipes on an intranet location and call them with the MP277 locally without a problem...
The main problem here is that the CSV files need to have the correct format, like Jesper also said.
The batching thing is not possible as well by this...
Okay,
CharlesM said:Ok here is a screen shot of the control functions screen where you can upload/download recipe's
Here is the main start screen for the web page that I made.
Here is the default start screen
Here is a sample of the HTML code that shows how to get the tag data into the web page
Code:<tr><th class="sph_th"><b>Press Program Information</b><td><br></td></tr> <tr><td class="sph_td"><b>Part Number</b></td><td class="sph_td"><MWSL><!-- write(GetVar("Recipe_Record_Name")); --></MWSL> </td></tr> <tr><td class="sph_td"><b>Part Count</b></td><td class="sph_td"><MWSL><!-- write(GetVar("PartCounter")); --></MWSL> </td></tr> <tr><td class="sph_td"><b>Parts Per Min</b></td><td class="sph_td"><MWSL><!-- write(GetVar("Parts_Per_Minute")); --></MWSL> </td></tr> <tr><td class="sph_td"><b>Cycle Time</b></td><td class="sph_td"><MWSL><!-- write(GetVar("CycleTime")); --></MWSL> </td></tr> <tr><td class="sph_td"><b>Mode</b> (1=Setup, 2=Single, 3=Auto)</td><td class="sph_td"><MWSL><!-- write(GetVar("HMI_Mode_Switch")); --></MWSL> </td></tr>
