panic mode
i tried it on different computers (different Office versions) and it always showed up correctly (oldest one was running vresion 2000). i think the defaults for your PC are not set correctly. check delimiter settings or
Separate text across cells
- <LI class=LPROC>Select the range of cells that contains the text values. The range can be any number of rows tall, but no more than one column wide.
<LI class=LPROC>On the Data menu, click Text to Columns.- Follow the instructions in the Convert Text to Columns Wizard to specify how you want to divide the text into columns.
