Window cross reference in Wonderware
ettikudiappan
Apr 2002
Singapore
131
Hi
I am using InTouch 7.11 for a project. There a lot of unused windows in this application. Is anyway to cross reference the usage of a window, just like we can cross reference a tag? I tried using the cross reference utility under "special" toolbar. It does not work for window names.
Blech. Wonderware (and most HMI software) seem to be horrible with text descriptions and cross referencing.
As long as you are only referencing the window by name, you might try doing a full printout to FILE using the Generic/Text only driver in windows, then opening that up in notepad and searching for occurances of the name to figure out if they are used.
A Less direct approach that I've used in trying to figure out other peoples large projects is to add a little script to the 'On Show' script of each and every window that just writes a line of text (Time, Date, and WindowName) to a text file somewhere. A week or two later, after the system's been in use, I browse over the text file.
Another thing is, it IS just a directory, make a backup copy of the entire application directory (zip it and store it safely), then just delete suspect windows one at a time. If you delete one you need, you can always import it back from the backup and convert the tags.
Got a repaired laptop back from warranty and loaded it up with all my software, unfortunately with my version V32.03 Studio 5000 I cannot change...
195
I am attempting to generate a VBA script within FactoryTalk View SE to open a Google Chrome webpage (PI Vision) when an object is right-clicked...
126
Hello. I am rebuilding an HMI from 2003 with the new software Factory Talk Optix. I have a pop up box with a trendline on it. I want the ability...
151
Hello, since i am starting using intouch, i need some help Actually i want to make in intouch a String input field. The operator has to insert a...
331
Hi everyone! Accidentally closed it and it wont appear again. Checked and unchecked the option and seem to make no difference. Running v7.10.00...
1,918
