WIntelligent Linx DDE communications
rrangaprasad
Feb 2005
28
Hi, im new in regards to PLC stuff.
Anyways, i am tring to to create communication between PLC and a visual basic executable file through WINtelligent Linx.
I have created a topic called "TimerPulse" thro' wintelligent linx and as i understand the application name for WINtelligent linx is "Icomwdrv".
I need the "toggling" PLC values (B3/2) to be shown in a text box on Visual basic. So in the text box, i linked the following:
LinkItem--> B3/2
LinkTopic--> Icomwdrv|Timerpulse
Further, i have also written the code for DDE initiate in visual basic.
So when i run the Visual basic, the text box should show the toggling values. But it says : "run-time error 282. No foreign application responded to a DDE initiate"
THE SAME THING WORKS PERFECTLY IS I USE RSLINX.
For that, instead of Icomwdrv, i use RSLinx and it works great.
I'm guessing then there is something woring in the way i'm creating the topic, etc in Wintelligent Linx.
In WinLinx, if i put superWho, it shows that it can see the PLC and also it shows that it is receiving something from PLC.
In configuring topic, the topic name is "TimerPulse" and i put in the info of the PLC connected (name, station no. etc)
I don't know what c'd be wrong.
Any help w'd be greatly appreciated.
Are you sure that you have a licensed copy of WinLinx, and not WinLinx Lite ? I presume so, because you said you can configure the DDE topic.
Otherwise you seem to have it right, like this:
Link Topic = icomwdrv|topicname
Link Item = B3/2
Link Mode = 1
I don't know if the server name and topic name are case sensitive. The B3/2 address looks OK, but you might try B3:0/2 to explicitly designate the word number.
WIntelligent Linx LITE???
YES
It is WINtelligent Linx Lite
So i won't be able to do DDE communication using Win LITE?
is that the problem?
Ranga
Hi all, I'm looking for an old "WINtelligent Linx ver 5.0.4" software, does anyone have it ? Thanks regards
5,362
Can anybody help me with Wintelligent Linx? the question is here: http://www.plctalk.net/qanda/showthread.php?t=13492&highlight=wintelligent+linx...
2,036
We have an old punch press machine. Many years ago (probably around 1990) a machine builder called Steelcase Inc (currently not in machinebuilder...
1,560
Hello, I'm working on a HMI upgrade project. It's from Rockwell Wintelligent View to PanelView Plus. I was wondering someone can help me to get a...
2,406
I have a problem with an Amp readout from one of our secondary treatment blowers on the Winview HMI. I've never used winview to search for plc...
2,285
