Chris Taylor
I once worked for a company that only ever used black for everything and then only used terminal numbers on the cable, so each cable would have a different number at each end and a row of relay bases would all have the identical numbering.
Very tricky to work with if there no drawings, but OK if you just had to change a base.
Chris
Chris
