Wire two output channels to one solenoid
Hi everyone, I need some help I new with omron plc. I using plc CP1L. When I do the program it's good and the plc is function as program. But when...
86
I am using a siemens output module and I saw that there is also 4 wire diagram for voltage output. Is there anyone who can explain the reason of...
2,820
Good afternoon forum members. We recently had a fuse blow on the wiring between a 1756-OF6CI analog out card and a control valve (which we have...
2,663
We have a stamping press with some prox sensors on the die for slug detection and we just ran into a problem where the output from one of the...
1,313
Do you use the PLC input or output address as the wire number or do you use the sheet-line number? The system that I am currently working on is a...
8,745
