Wireless MPI (Siemens S7)
DeHulk
Mar 2003
74
In a crane we have always problems working at te program cause it's difficult to work save using a PG while the crane is working !
So i wonder if there is an easy way to setup a wireless conection to the S7 using the MPI-port ?
DeHulk,
This is something that I looked into a little while ago to enable us to remotely monitor our S7 200's (all our 300's and 400's have ethernet cards fitted). I found a company that make a MPI/Profibus to ethernet convertor, using this we would then plug it into our wireless LAN system. The cost of these convertors was around £280 or 390 euros. As we already have a wireless LAN saturating our site this worked out as a very cheap option for us.
Our wireless LAN is setup using Breezecom Products and the MPI convertor is from Que Associates LTD. Click on convertors and then MPI to Ethernet.
This might give you some ideas
Paul
Another but probably slightly more expensive option would be to install a GSM modem on the MPI port at the plc and use Siemens Teleservice software to remote access the plc. This works very well and is a neat solution.
when i use such an adapter from MPI - ethernet ...
when you connect two PC's with wireless lan you can make settings at both PC ..but how about the connection to PLC ?
DeHulk
If you are referring to the MPI - ethernet converter as supplied by Que Associates LTD, See my first reply for the web site, then all the required drivers to enable you to connect to the PLC via simatic manager are supplied with the converter.
Paul
G'day, I was wondering if there is a solution to this problem I have. We have a production line with 15 Siemens PLC's. They vary from S7-313C...
3,508
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,372
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,044
Hi All, I am working with an outside vendor on a project, and they have asked if they can use Wireless IO link for one of their remote IO blocks...
1,136
Hello everyone, I have read a few threads regarding setting up an AP to wirelessly communicate with PLC networks, but I have a unique question on...
591
