wireless PLC controllers ??
ebda3at
Jun 2015
saudi
dears
i try to build small system for buses station in my company. there is main station for buses and many building, i want to fix bored in main station contains light for each building and also fix push button front of each building to call the bus. when they push the button the bus driver will see the light in bored. i want method to connect all push buttons and main bored wirelessly.
Greetings,
The Fx2424 has the ability to incorporate a ZigBee transceiver and based on IEEE 802.4.15 standard. More information about this feature can be found in section 19 of the manual:
http://www.eternity-sales.com/tri-plc/files/F2424-UserManual.pdf
Should you rather go another route, we also offer a wireless data relay point (802.11) that connect to the serial port of any controller you choose, whether it is another PLC altogether or another TriPLC product. More information is available through the following link:
http://www.eternity-sales.com/WirefreeCNC/hardware.htm
Disclosure - ESI is an authorized distributor for Triangle Research and CNC Computer Integration.
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,026
Hi, I have a compact battery powered home robot mower for fun project and am looking at basically only putting a remote I/O unit in the battery...
1,063
I am sure this has been talked about before but searching there is a ton of other things that come up... I have a customer thats installing 16...
18
7,154
Hello Gentlemen, I've just registered and this will be my first post :). I am still a beginner in PLCs especially in communication...
1,156
Looking for some help. I posted this on the Ubiquiti forum: Just joined the community, please be patient with me as I have, being kind with...
28
6,451
