Wonderware Historian
Jezz
Dec 2002
Kendal
399
HI All,
I've got a problem with a couple of devices communicating to our historian server where the coms is lost (normally someone switching something off or just a random coms issue) what I'm wanting to do is set up an even tag to email me when we lose coms on a I/O server topic , the email is set up and working, I'm just struggling to fine the best way to trigger that an I/O server has failed any suggestions welcome ?
Thanks in advance
Are you using Intouch as well?
You could monitor Intouch's connection to the DA Server with an IOStatus topic or monitor the DA server connection to a specific device with the $SYS$Status tag?
We have InTouch but not on every topic most are daservers to specific items, so I'm looking to do it all on the server if possible.
Is the issue specific to the end device being switched off, or comma are just lost ie logging is missed..?
I can think of a couple of solutions, but does depend on what the root cause is & what platforms you are using.?
A simple option could be to the a periodic query on a tag per topic looking for a change from the last value, but that relies on a changing tag...
I often use a clock.second tick for similar
We have had both an item being switched off ( or it's local network switch failing) and an I/O server hanging up in both cases we simply stopped receiving data, how would you do a periodic query on a tag changing value SQL is not my first language LOL
I've tried using a Generic SQL Detector to trigger an Event tag but keep getting errors,
The code I used was:
SELECT OPCQuality
FROM runtime.dbo.DiscreteLive
WHERE TagName IN ('Work-Shop-Email-Test') AND OPCQuality = 192
and that would return a table with a value of 192 if connected and no table if disconnect, I'm not sure what the Detector is looking for when using generic SQL.
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
176
So I'm trying to make a tag I created in WonderWare Historian display the correct tag values on the inTouch client but it is currently showing...
1,557
Hello there, Our plant is running Wonderware Historian on a Virtual Server and every few days I'm losing comms to my PLCs. Usually I can simply...
2,072
Hi all, I found some interesting issue from my Wonderware environment. At my Trend table option, if i select "both", the Trend table is not...
3,655
Hello, I want to monitor Wonderware historian's heartbeat and trigger a fault if Historian is not communicating /offline in PLC. Currently my...
790
