Writing Array values to panelview
Burch
Jun 2014
Michigan
54
I have an application where we are setting up recipes for our system.
I have a an array of UDTs to store my recipes in the PLC (CLX), We are using a panelview 6 plus.
I have one screen to enter the recipes, it seems like it works fine. Problem is we have another screen that will display the values within the recipe...when I drive down though the array to chose the tags for my recipe view screen, I am getting an error saying "The item is no longer available". I am entering a recipe number in the view screen that will point to the array member (recipe) I want to view.
Any ideas?
Thanks,
Burch
Before doing anything, can you see the data you need to be displayed on our PView with your rslogix5k, if positive then check your PV displays. If negative, check your program. Your data is written somewhere then is erased or moved.
Hi Thanks for reading this post. I Having trouble writing Wonderware array values to a compactlogix PAC. I can read the values through a...
4,227
Does anyone know of a way to set the values of strings in a string array in a Logix5000 program when offline (before connecting to a PLC) so when...
3,181
I am working on an RSView project that was converted from a 1400e series panelview and PLC-5 setup. I had quite a number of momentary push buttons...
4,331
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
306
Hi. Not the fist time I'm saying this but just to give a background. 95% of my PLC programming has used Schneider over the last 10 years on...
66
5,087
