xbtgt1000/vijeo designer -micrologix1000 df1 cable
franzela
Jan 2011
shakespeare
hello,
I am struggling to find the right communication cable pinout between vijeo designer and micrologix 1000 df1 for simulation purposes, and XBTGT1000 and micrologix 1000 df1. It didn't work so far, I got errors in Vijeo Designer simulator, depending on the driver configuration flow control of 'plc returned error code 10'(?) or 'packet send incomplete.Possible cable problem'.
Can anyone ,please, direct me with the right cable pinout and configuration flow ?
Thank you,
Best regards
See pdf's below. Not sure about the simulation though. If fact I'm not sure that the pdf's below will help with the HMI to PLC.
But Google found these.
Hi, Mickey,
Thank you for your reply.
1761-CBL- PM02 is the micrologix 1000 programming cable, if I am not mistaking, With it I can see micrologix in rslinx, but not in vijeo designer simulation.
Another version I tried was to connect this cable through an adapter which connects only Rx, Tx and GND, and again is working with RS linx but not with Vijeo Designer.
Reinstalled Vijeo designer: no change.
Confusing, for me at least...
All the best,...o_O
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
184
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
182
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
481
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,673
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
1,001
