craig_avanzar
The true reason to only ground one end is to avoid "ground loops".
This is where a current is passed along the shield because it is connected at both ends and is therefore a complete circuit between two different sections of the machine that may have different potentials.
The magnetic field induced from the current flowing through the ground loop could cause more interference then using no shield at all.
Actually, having it grounded at only one end is WORSE for blocking RF, but the negative impact of potential ground loops is a bigger risk, so we only ground one end.
Here is a good explanation: http://www.epanorama.net/documents/groundloop/cable_shielding.html
Well I thought I knew to only ground one end, as it was explained to me, otherwise it would act as an antennae, BUT now I'm confused again. I suppose that there is more than one right way to do this.
