Yaskawa MPiec to PanelView Plus over Ethernet/IP
aiki202
Aug 2007
Pennsylvania
178
Has anyone ever set up a Yaskawa MPiec controller to an AB PanelView Plus terminal over EtherNet/IP? I know these two items can communicate over Modbus TCP but I would like to pass something beyond Bytes and Bools...such as String data types.
Hello!
Any progress with your request? I am facing the same problem today. I am trying to connect a MP2600iec with a Cmore touchscreen EA7/ Modbus/Eth ip. Can you share your progress?
I am not sure how Ethernet/IP can handle different data types than Modbus/TCP. I have done strings(byte array) to 3 different types of HMI's(Pro-Face, Maple System, and Exor) from MPiec controllers. The Yaskawa can certainly convert strings to bytes, but the question is can the Cmore do it.
Anyone ever setup a Wago 750-352 Field Bus Coupler as remote I/O to a Yaskawa MPiec controller via Ethernet/IP? I have two 750-1406 discrete...
1,762
Is there a way to efficiently edit the variable database in a Yaskawa MPiec controller (using MotionWorks IEC Pro 2)? RA allows export/import...
2,442
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
129
Hi sir I has a equipment use Yaskawa GL60s PLC via P150 developer,we want to upgreat the system to New,but we have some problems For example: On...
149
Hi Everybody, this may be one for you motion control guys. We have been tasked with interfacing some Yaskawa drives into a project where the...
264
