Zebra DS3678 wth STB3678 bluetooth problems
userxyz
May 2002
any
2,768
We have used DS3678 Zebra scanners with STB3678 cradles connected to EA3600 interface modules that converts to TCP. The scanned barcode is send to a SIemens PLC via its CP443-1.
The problem we had last week... the operator wanted to scan a product and he got 4 ignoring beeps with the bluetooth sign blinking red. I tried to reconnect on TCP by using the CP_CNTRL block, but the problem is bluetooth, so this had no influence. We needed to disconnect and reconnect the power from the cradle to be able to pair agan between the scanner and the cradle ???
After searching on the web I found someone with exactly the same issue and without replies on his post:
In an office environment I can understand that a disconnect/reconnect is not a big issue... but in an industrial environment this is not done. After searching a little on the net... I installed 123 scan and could do a firmware upgrade of the scanner:
The scanner its firmware is upgraded. I am not sure but I think the cradle also has a firmware running, but I cannot upgrade it without a special USB cable, wich I don't have... Maybe I should order a USB cable for the cradle to be able to upgrade the firmware as well.
Anyway, are there people out there who have experience with zebra scanners ? What are your toughts about these scanners... are the reliable, are they any good ?
Thanks,
Kind regards,
Combo
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
387
Hello, I am very new to the plcs and am working on a project that requires a fixed mount barcode scanner to scan packages as they move along a...
203
I have an L24ER-QB1B with a 1769-ASCII card in slot number 4. I'm looking to send data to this zebra printer after every completed sequence. I'm a...
455
Hi All, I currently have an issue to establish connection between my PLC to Zebra Printer. On my side don't have the ASCII card Module to use...
782
Hi All Trying to get the PLC to send a commant to the printer to prinnt a lable. evarything is setup except RS linnx cannot see the printers and...
389
