169
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
26
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
Morning, we are changing how we control an HMI by having our users sign into iFix which then sends a tag to the HMI. Looking at a specific DINT...
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
34
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
78
Hello, I've searched long and hard for this and found a great thread from 2008 about animating pipes and it turned out it was a bit of a flame...
36
1,144
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
16
646
57
172
Greetings one and all. Does anyone have any idea why the relays in an Omron OC211 output module do not function, despite the indicator LEDs...
43
11,015
I am working on an older system where they are switching out the weigh in motion scale on a conveyor system from an AP Dataweigh to a Mettler...
1,227
115
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
94
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
800
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
16
17
649
I need to purchase a few Large soft starters for our plant and we prefer to stay Rockwell. We have purchased SMC Flex 150 in the past and they...
48
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
24
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
25
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
477
Hi there, I'm new to plc programming and was wondering why I get this error code when I run my simulation for these temperature sensors? What I'm...
39
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
56
310
