Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
71
I am working on an older system where they are switching out the weigh in motion scale on a conveyor system from an AP Dataweigh to a Mettler...
1,234
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
40
17
246
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
27
I'm a beginner at this, I have points with x y z coordinates that I want to record on s7-1214 and use to move the axes for those points. How can I...
141
70
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
16
129
19
677
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
108
Morning, we are changing how we control an HMI by having our users sign into iFix which then sends a tag to the HMI. Looking at a specific DINT...
36
I'm using a powerflex 525 drive communicating over Ethernet. I'm having to cycle power if I have a fault such as Ethernet loss or if the building...
2,364
29
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
43
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
96
Hello, I've searched long and hard for this and found a great thread from 2008 about animating pipes and it turned out it was a bit of a flame...
36
1,156
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
16
660
60
177
Greetings one and all. Does anyone have any idea why the relays in an Omron OC211 output module do not function, despite the indicator LEDs...
43
11,026
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
805
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
23
I need to purchase a few Large soft starters for our plant and we prefer to stay Rockwell. We have purchased SMC Flex 150 in the past and they...
53
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
29
