A-B PLC5 addresting question
CDF1909
Nov 2003
Mason, Ohio
I am trying to follow the ladder logic in an A-B PLC 5/80, I'm using RSLogic 5, ver. 6.30.
I'm trying to find where and how some data is stored. I come accross several address, the format I dont understand.
Such as an "ADD" instruction Add Source A N[N27:0]:59
Source B N27:4
DEST N27:60
I don't understand the address for Source A, ie the brackets.
Will someone please enlighten me to how this address works?
Never seen an AB PLC, nor it's software, but from what I've gathered reading posts, that looks alot like indirect adressing
Think it's best explained as -> N[value of N27:0]:59
N27:0 contains a value, lets say 26, then the first destination address could also be written as: N26:59
But then again I could be wrong...;)
Jeebs nailed it - even without ever seeing the AB software! ... the demo in this post won't give a better explanation than the excellent one that Jeebs has already given - but it might make it easier to work with the software ...
Good job! This is how it works.
Watch out - most likely N27:0 is changed within the program. Then the indirect address would change.
Thanks;
Ok I have seen the light. The way Jeebs explained it,and the post that Ron pointed to were both helpful.
Yes, Oakley the value of N27:0 is changed in several places in the program. That was one of the reasons I had a hard time following it.
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
154
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
372
Hi, can anyone help me get a pdf file for this RSP files. They are from a PLC5. Thanks
520
Hello all, I am seeing this behaviour where an integer file (N46:33), has an integer in binary (11110) which is 30 in decimal. I did a...
519
