Control logix bootp
darrenj
Feb 2005
Ottawa
1,003
I have an existing Control logix setup, 2 racks communicating over ethernet. recently on a power cycle the modules start up in Bootp mode. This hasnt happened before, both modules are supposed to have a fixed IP address, When i go on line and check the module properties the bootp box is not checked.....
any ideas??
D
251
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
378
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
758
Possible for two processors in same rack to have separate motion groups across a single Kinetix Rack using a single EN3TR? One 6500/5700 rack, 8...
426
Hi all! I am hoping to find some help understanding the ABB VFD Connection to my Rockwell PLC. I have set up the VFD parameters based on...
669
