Control logix thermocople ,CJC purpose
asim_rana
May 2005
50
WE are using 1756-IT6I for thermocouple inpuuts.We had following queries.
1. What is the purpose of CJC?
2.When it is used?
3.What is Remote CJ compesatation?
4.If we will not use CJC (connecte at terminal 10 & 14 ) what will happen?
Cold Junction Compensation is used to make the reading of the thermocouple more accurate. Think about it, you have a T/C, which is a junction of dissimilar metals. Now, for local CJC, you connect your T/C Leads to screw terminals. Guess what? There are two brand new junctions of dissimilar metals, which creates new thermocouples.
The CJC is connected in exactly the same way to the same types of screw terminals (for example) so that the error voltage produced by the extra junctions can be nullified, so ONLY the actual voltage generated by your measurement junction is measured.
Remote CJC's are used sometimes if you are actually going through more than one junction from the actual T/C to the measuring device.
261
hi all, i have a plc i need to get info from for a site im working on: I have a 1764 Micro Logix 1500 LSP Series C (See Attached Image) im...
383
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
767
Possible for two processors in same rack to have separate motion groups across a single Kinetix Rack using a single EN3TR? One 6500/5700 rack, 8...
428
Hi all! I am hoping to find some help understanding the ABB VFD Connection to my Rockwell PLC. I have set up the VFD parameters based on...
682
