Counters
Rami Dandashi
Dec 2002
Jeddah saudi Arabia
Hi, can any body help to solve a problem?
how can i use the value "of a counter" as set point of another one!
I mean if C1 counts '3' how this '3' will be set automatically as the set point of C2!
Thanks of help anyway
This assumes that by the 'value' of the counter, you mean the accumulated value. The answer will depend on the brand and model of PLC you're using. When you program the counter function, are you restricted to entering a constant as the preset value or can you enter an address like C1.ACC? If you are limited to a constant, you will need to add another rung with a MOVE or COPY instruction:
______
| MOVE |
C1.ACC| |C2.PRE
|______|
Let us know which PLC you're using and somebody will be able to give you a better answer.
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
161
Hey guys, thanks for reading. I am trying to use a micrologix(1000 or1500) to control 3 hydraulic pumps. I have a time clock to give a signal to...
38
3,471
iFIX 5.5. We have alarm count database tags with SIM driver and I/O address = "C:AREA-SD:ACK" which is suppose to count the acknowledged alarms in...
1,411
https://www.youtube.com/watch?v=zTOOYWMJg9M . Specifically see 1:46 to 2:11. 3. The Cell PLC is in constant communication with two other field...
3,163
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,718
