GE QuickPanel+ Graphics Library
jawad rasool
Feb 2012
Lahore
51
Good Day,
I'm looking for some help regarding exploring Graphics Library in GE Quickpanel + HMI.
I'm working on Proficy Machine Edition Version 8.6 trying to make Vessals and Valves with 3D Effects.
I am unable to find any Symbol Factory as available in FactoryTalk ME or Schneider Vijeo Designer HMI.
I've also tried to access ToolChest but it pops out an error message "Cannot creat file : Access is Denied".
If anyone have experience with GE QP+, please help me out.
I am looking for answers too, about QuickPanel+; i hope we are not the
only two here.
The route you looking, on my PC, using Windows 7 and PME 8.6 is:
C:\Program Files\Proficy\Proficy Machine Edition\fxView\Symbols
There is no much usefull symbols about valves; good look.
TIP: Use the "Picture Browser" for image preview, on Navigator window from
Machine Edition enviroment, Utilities tab.
Good luck finding 3D graphics there, this is called a "QuickPanel" because it is "Quick" and "quick" to build an HMI with, its not "Flashy".
If you want flashy graphics buy one of the "Symbol Factory" products or buy "Symbol Factory" and add it to the library.
It is capable even capable of using "Smart Objects" but you will need to build your own for some odd reason GE does not supply them with this product. However I have seen people use the library that comes with iFix and Cimplicity HMI SCADA products.
only two here.
Android94, I've already planned to do so by using image files via "Picture Browser", but this approach may increase the HMI screen size and it will take time while loading/navigating the HMI screens.
RussB, thanks for the pointing out the use of Cimplicity library. I'll try to find a way to import the Cimplicity library to Proficy MAchine Edition.. :)
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
354
Dear colleagues, hello to everybody! I have a problem with Quickpanel IC754VBI06SFD-GF Proficy Machine Edition Runtime 6.5 QuickPanel View V2.00...
673
Dear guys, I am not a programmer but I can do simple things myself. I'm stuck with the following. if I want to extract a value from my rx3i...
46
4,835
does anyone know if you can make a graphical panel with the quickpanel+ 7inch that you can only open with a password? for example a panel where...
1,843
Hi all, I need some help in uploading of QuickPanel gp570-sc21 program to PC. I load from QP to PC the project through the working HMI-CAB-C49...
2,034
