S5 CPU100U programming s/w & cable
djthune
Aug 2010
Illinois
I need to find current programming software and cable to connect a Windows Laptop to an S5-100U PLC. The model on the CPU is 6ES5 100-8MA02.
Does this take a standard serial cable to connect or do I need another special cable? What is the best software to use? I found some on Softwaretoolbox.com and they have several cables as well.
Thanks in advance.
djthune
I found the software and cables. Software looks straitforward enough. I'm concerned a little bit on specifying the cable. I can't seem to find any specific information from Siemens or elsewhere on what the port on the front of the PLC is. I would hope it would be a standard serial port, but the IBH cables on the Software Toolbox site seem to indicate otherwise? Can anyone point me to better info about the programming port on the front of the CPU? (CPU model 6ES5 100-8MA02)
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
125
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
119
Hi all, i am the new controls guy at the plant and i have inherited a pc from the previous controls guy with Siemens tia portal version 16 and 17...
20
919
I need to pull the program off of an old 90-30 so I can convert it to Allen Bradley. This is my first time messing with GE and I don't have the...
91
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
487
