TIA Translation tool
bcz14
Feb 2023
NY
Hi, I'm trying to find the best way to translate a full TIA Project from German to English. I was looking into the TIA Translation tool and it seems that I have to create a dictionary first in order for it to translate the project. Can these dictionary files be found/downloaded from somewhere or is it something I have to manually create every time?
If anyone can recommend a good/efficient way of translating projects that'd be great. Also, this is my first time in the forum so I apologize if a similar thread already exists.
Bump.
I have the same issue, the same question. I have loaded the exported text files into the Translation Tool... but no dictionaries come with it.
I must be missing something.
Bump.
I ran into this before. Basically you have to make your own dictionary.
I used a google sheets extension that would take the exported texts from TIA and automatically translate to English. From there I used that google sheet and imported it into the translation tool.
I'd give more detailed instructions if I could. It's been almost a year and I got a different job since then.
In short, it will not translate anything for you. You have to do the leg work and then it will change everything for you.
I'm pretty well a 100% GE/Emerson Rx3i programmer, and zero practical experience with Siemens programming. However I have just been given a PDF...
1,592
253
Hi guys , I'm new with Allen Bradley, but I have experience with Tia portal (s7 1200 ,s7 1500) I want to convert my project from Tia portal to...
208
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
173
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
310
