TIA V15.1 hardware configuration - module names
naturephoenix
Jan 2015
Vienn
181
Hello, I managed to get inside my User program Number of slots and channels of my hardware configuration. In order to improve control system I want to include inside every Module Slot its name. Unfortunately Get_Name function return name of I/O device, I need module name as a string data type. ModuleStates returns module states, but module name(for example "DQ 16x24VDC/0.5A ST_1") I haven't found yet. Does any of you guys find out how to get module names in user program?
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
517
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
396
Hi am new to TIA and i have a challenge when i archive the project it;s being saved as PDF. How to l change from PDF to normal TIA. Your...
634
Is there any possibility to convert the project in TIA V17 Wincc Professional to TIA V15 Wincc Professional or Wincc Advance?
1,279
I have 2 TIA Wincc projects. One project is in TIA V17 Wincc Professional and other project is in TIA V15 Wincc Advance. How can I copy the Wincc...
1,278
