TIA v15.1
chama mulenga
Sep 2009
Lusaka
42
Hi am new to TIA and i have a challenge when i archive the project it;s being saved as PDF. How to l change from PDF to normal TIA. Your assistance will be appreciated.
Please post screenshots of the steps you are following.
Archiving a project should be simple. In the text menu at the top of the screen, click Project then Archive, then OK (this button may be called Archive or something else. It is next to the Cancel button).
Side note: It is more proper to refer to the software as TIA Portal or Portal, not TIA only. TIA is a concept that describes more than one software platform. (Though calling it TIA will confuse no one.)
Not gonna lie, I use it daily, and still for some reason I often read TIA as "Thanks in Advance", and briefly confused, and then figure out my mistake and go on with my day....
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
354
Is there any possibility to convert the project in TIA V17 Wincc Professional to TIA V15 Wincc Professional or Wincc Advance?
1,237
I have 2 TIA Wincc projects. One project is in TIA V17 Wincc Professional and other project is in TIA V15 Wincc Advance. How can I copy the Wincc...
1,250
Hi everyone i'm trynna install Tia portal v15 The installation starts normale but it suddenly stops asking for a reboot , When i restart the...
32
8,262
