WinCC flexible Question
brian7619
Nov 2011
Ogdensburg
Hello all,
I have a question regarding a WinCC hmi program. When I look in the error message section of the program under discrete alarms I find a trigger bit corresponding to an error message that will show up on the hmi. I am wondering how to find that in the s7-400 program. The version of WinCC is 2008 sp3 v1.4.0.0_1.16.1.16 and the S7-400 is v5.5 + sp2 K5.5.2.0. I am just looking to be able to trace errors back from the hmi messages into the ladder logic for troubleshooting purposes. Very new to this so if anything is worded improperly or any info is missing I apologize.
Thanks,
Brian
You should see the trigger address of the trigger tag by the alarm. Note the bit for the alarm does not match the address directly. This is the Big-Endian Little-Endian bit swap.
I do see the trigger address just not sure how to find it in the program, for example in your screen shot how do you locate where DBX 0.3 is? I tried searching using the "GO TO LOCATION" command but had no luck
We use Siemens WinCC flexible 2007 for HMI. In the HMI in one screen when one object pressed a faceplate open. In the faceplate many object there...
1,849
The line in scripts is if SmartTags("Enable\En_Maint_Enable") Then set Bit SmartTags("En_Open"); I did not understand what is the meaning of...
1,648
We use WinCC flexible 2007 for HMI. There are 3 HMI . One is in the pulpit and the other twos are in local. From local it has ability to jog and...
1,883
Could anybody tell me how these alarms got data (attached alarm). I have highlighted alarm no 1521 for example. The Trigger tag for this alarm is...
2,710
I have attached here two screen shot. The Local button Animation --- visibility is set as tag EN_LSTN_SPO. But this tag is internal tag. In this...
2,225
